Hello Guest it is November 22, 2026, 06:02:32 PM
Author Topic: "index distance not in allowed range" message  (Read 8321 times)
« on: July 12, 2019, 10:34:06 AM »
Hi there,
can anyone enlighten me whether the magic number in Mach3, indicating minimum distance b/w Home switch
and encoder Index mark can be adjusted? For my rotary table i've found i cannot move them closer
then 15 degrees to avoid distance range error. I think it's too far.
thanks!
Offline TPS
  •  2,627 2,627
Re: "index distance not in allowed range" message
« Reply #1 on: July 12, 2019, 12:53:39 PM »
indexed homing sounds like external Motion Controller, in the plugin config maybe?
« Reply #2 on: July 12, 2019, 04:22:16 PM »
yes, that's it! I was silly enough not to browse CSMIO_IP_A_plugin.dll with a text editor!
Then I should re-address the question to SC-lab stuff.
Thanks a lot!
