Hello Guest it is November 13, 2026, 09:34:34 AM
Author Topic: Lost my ability to select jog, step or MPG  (Read 13128 times)
« on: September 04, 2007, 07:39:26 PM »
I have lost my ability to use my keyboard for jogging, in fact I can’t switch between step and continues or MPG. I can not toggle between Jog and step nor do any of the indictors light up. It worked fine when I calibrated the machine, but since then it stopped working.  I had added the spindle and coolant start/stop function so I backed up and remove it and the pin outs but nothing changed. At this time I only have use of the job buttons on the screen in continues mode, which is impossible to move with any precision. Could I have turned something off?
Fred
Re: Lost my ability to select jog, step or MPG
« Reply #1 on: September 04, 2007, 08:00:22 PM »
Do you have jog, on/off turned off on the program run screen? Can you jog on that screen?
« Reply #2 on: September 05, 2007, 06:45:15 AM »
Where would you turn it on/off? I checked everywhere and can't find any such command. If I use the tab key the MPG screen comes up and I can move the tables useing the arrows on the MPG screen and I can change the per cent of speed, but other then that nothing else works.
Fred
« Reply #3 on: September 05, 2007, 08:00:54 AM »
On the program run screen, under tool info. See The screen shot.
« Reply #4 on: September 05, 2007, 04:57:14 PM »
You hit it right on the head. The answer was right in front of me, but for some reason I didn't see it. Thank you.
Fred
« Reply #5 on: September 05, 2007, 06:33:08 PM »
Your welcome Fred, How do you think I knew that?
 ::) Because I have done that too,  ;D
