Hello Guest it is November 27, 2026, 02:45:50 PM
Author Topic: shape doesnt come out exactly as designed  (Read 22115 times)
« on: June 25, 2019, 05:46:27 AM »
the router accuracy  looks like this (see picture). I dont have used cutter compensation.  I use a 0.6mm router bit. As far as I know just follow the line (very basic).It turns out dramtically bad.
« Last Edit: June 25, 2019, 07:14:20 AM by Tweakie.CNC »
Offline TPS
  •  2,627 2,627
Re: shape doesnt come out exactly as designed
« Reply #1 on: June 26, 2019, 04:20:28 AM »
Looks like backslash in X/Y axis
« Reply #2 on: June 26, 2019, 12:09:43 PM »
I have solved it, it was backslash in the y direction, the coupling to the steppermotor wasnt tight and could move about 1mm
