Hello
Guest
it is
November 22, 2026, 10:33:22 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach Screens
Works in progress
Coming soon to a lathe near you
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Coming soon to a lathe near you (Read 58910 times)
Graham Waterworth
2,785
Yorkshire Dales, England
on:
June 17, 2019, 08:16:31 PM »
Well folks here is a new lathe screen.
I am just finishing off a few bits and then the Mach3 version will be ready for you all to try.
This is a wide screen set best at 1366 x 768
This was done for education so its colourful and easy to read and use. Most of what you need is there if its not well its tough.
Bug fixes is all that will change.
Last Edit: June 18, 2019, 04:12:01 AM by Graham Waterworth
Re: Coming soon to a lathe near you
Reply #1 on:
June 18, 2019, 04:28:35 AM »
Graham,
Nice work on the screen set.
Overloaded
4,923
Reply #2 on:
June 18, 2019, 05:32:06 AM »
Hi Graham !
This one looks really good.
I like the way the left side stays the same on all and has all of the pertinent goodies.
Anxious to try it out.
When do expect to post it ?
What are you going to charge for it ?
Thanks again,
Russ
Graham Waterworth
2,785
Reply #3 on:
June 18, 2019, 08:03:12 AM »
Here are some images of the Portrait version of the screens, again 768 x 1366 or can be scaled to any widescreen size.
Last Edit: June 25, 2019, 07:41:36 PM by Graham Waterworth
Graham Waterworth
2,785
Reply #4 on:
June 22, 2019, 07:38:07 AM »
A few more screen shots
Graham Waterworth
2,785
Simple Colourful lathe Screen Set Mach3 Only
Reply #5 on:
July 21, 2019, 03:54:04 PM »
The horizontal screen set is now available to download in the finished screen section.
https://www.machsupport.com/forum/index.php?topic=41385.msg271329#msg271329
Last Edit: August 13, 2020, 08:16:09 PM by Graham Waterworth
Print
Pages:
1
Go Up
« previous
next »
