Hello Guest it is September 29, 2026, 01:39:35 AM
Author Topic: too slow for pulley using min  (Read 14844 times)
« on: June 13, 2019, 07:13:32 AM »
I am getting messages that either say RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START. ALSO IT SAYS TOO SLOW FOR PULLEY USING MIN.
looking for suggestions that may help. I have a Galil motion control. I design on FLEXI and get my G CODE from ENROUTE
Re: too slow for pulley using min
« Reply #1 on: June 13, 2019, 07:32:18 AM »
"Too slow for pulley" means you are commanding a spindle speed lower than the minimum set pulley speed. If the speed is what you want, change the min pulley speed to a lower value.
Radiud to end of arc usually means you have programmed in incremental IJ, and have Mach set to absolute IJ, or the other way around.
« Reply #2 on: June 13, 2019, 07:44:29 AM »
So when I try to cut a square for example the program will lose its place and then somehow finds it way back? could this be a problem with the motion control?
Motion control
« Reply #3 on: June 13, 2019, 08:56:04 AM »
I have several different messages I need help with. I have a waterjet. everytime I cut the machine either stalls out and says radius to end of arc differs from radius to start. or too slow for pulley using min. At this point I have to completely shut down everything and restart sometimes just to get the machine to jog. Any solutions?
« Reply #4 on: June 13, 2019, 11:11:29 AM »
I already gave them to you.
Offline TPS
  •  2,627 2,627
« Reply #5 on: June 13, 2019, 11:18:39 AM »
goto Settings and check witch pulley is selected
goto Config -> Spindle Pulleys and check Min value of selected pulley
Offline TPS
  •  2,627 2,627
« Reply #6 on: June 13, 2019, 11:21:21 AM »
for radius Problem goto Config -> General Config and make Setting correspondig to post processor
