Hello Guest it is November 07, 2026, 01:36:18 AM
Author Topic: LED not showing with transparency  (Read 25723 times)
« on: June 12, 2019, 08:20:59 PM »
Hi All,
I have made some LED buttons in Real Draw and exported them as PNG's with transparency, in Machscreen they look good with a clear background but when I load the screen into Mach3 I get a black background not the transparency.
Can you give me any idea what I may have done wrong.
YP
Re: LED not showing with transparency
« Reply #1 on: June 12, 2019, 09:02:04 PM »
Can you upload the files?
Usually, a black background means the order is not correct. Maybe the LED on top of the button?
You need a 100% transparent image for the button. The LED doesn't need any transparency. Button on top.
Offline TPS
  •  2,627 2,627
« Reply #2 on: June 13, 2019, 01:09:08 PM »
or use a tranparent button
« Reply #3 on: June 16, 2019, 01:17:44 PM »
Thanks for the help so far but I need a bit more.  I have the LED issue sorted but no matter what I do I can not get the toolpath window on top of the background image.
The background image is on page 0 and the toolpath is on page 3 and is hidden behind the background.  I have tried in Screen4 to move the images to back and had it in Machscreen but nothing seems to work.
Any help much received.
YP
« Reply #4 on: June 16, 2019, 01:39:39 PM »
Hi YP
with MachScreen make sure "Multiple selection" is checked (second icon from the right in the toolbar. If you hit the led, a window opens up showing the components in the current order. Change order by tragging the LED up or down to your desired order.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #5 on: June 16, 2019, 01:56:12 PM »
Hi Klaus,
thank you for the reply, I have the LED sorted.
My problem now is how do I select the global background image and the tool path on page 3 to make the toolpath come to the front?
YP
« Reply #6 on: June 16, 2019, 08:53:07 PM »
I believe that anything on Page 0 will always be on top?
« Reply #7 on: June 17, 2019, 04:50:28 AM »
Thank you Klaus for the PM and getting me sorted.
« Reply #8 on: June 17, 2019, 06:40:54 AM »
Hi ger21
you are right, with the exception images on page 0 stay in background
Klaus
