Hello Guest it is November 13, 2026, 02:48:57 AM
Author Topic: My stepcraft DL445 laser leaves a path  (Read 38771 times)
Offline TPS
  •  2,627 2,627
Re: My stepcraft DL445 laser leaves a path
« Reply #20 on: June 13, 2019, 01:03:59 PM »
well, walked through the stepcraft Manual, not getting 100% clever, but here a "try"
pls try also Output1 Active Low Setting.
« Last Edit: June 13, 2019, 01:05:31 PM by TPS »
« Reply #21 on: June 13, 2019, 03:04:34 PM »
Same thing my friend, I tried with active low off in output1 after I tried on and nothing new happened, thanks for your time
Offline TPS
  •  2,627 2,627
« Reply #22 on: June 13, 2019, 10:59:02 PM »
i will try to contact stepcraft to get more information
« Reply #23 on: June 14, 2019, 02:42:08 AM »
thanks, i tried a couple times and they said "we dont have technical service support to mach3"
Offline TPS
  •  2,627 2,627
« Reply #24 on: June 14, 2019, 08:14:31 AM »
next try.
Offline TPS
  •  2,627 2,627
« Reply #25 on: June 14, 2019, 08:25:47 AM »
got some more documentation about Pins of laser Interface.
and sorry, i was wrong in an earlier reply M11P1 means Switch Output 1 ON
« Reply #26 on: June 14, 2019, 10:50:43 AM »
i tried with the last file, laser never on, i activate low in output 1 and the laser never off, i bought a UCCNC  ;D
now i need to configurate
Offline TPS
  •  2,627 2,627
« Reply #27 on: June 14, 2019, 01:55:38 PM »
OK, one eye is a Little bit sad to hear, that you gave up, but only one eye. ;) ;)
« Reply #28 on: June 14, 2019, 03:43:08 PM »
Everything is perfect with UCCNC, my machine was created to use with this software, that the reason doesn't works perfectly witc Mach3, thanks to all the people who helped me, this is the best Mach3 blog ever!
  •  9,377 9,377
« Reply #29 on: June 15, 2019, 12:33:22 AM »
I am pleased to hear that you now have your machine working as it should - your latest engraving picture looks excellent, good fortune with your future laser adventures.
