Hello Guest it is November 13, 2026, 02:49:11 AM
Author Topic: My stepcraft DL445 laser leaves a path  (Read 38779 times)
  •  9,377 9,377
Re: My stepcraft DL445 laser leaves a path
« Reply #10 on: June 12, 2019, 07:31:33 AM »
The Laser manual is not clear if the ON/OFF signal is active High or active Low.
Assuming the laser is connected by the 15 pin D-Sub connector then, using a voltmeter measure the voltage on Pin 13 (with respect to GND Pin 10).  Is it High (5Volt) when the laser is ON and Low (0Volts) when the laser is OFF ?
« Reply #11 on: June 12, 2019, 10:52:40 AM »
What a mess haha 😂 I think is better if I buy it  a old computer with LPT port, right? What do you think?
  •  9,377 9,377
« Reply #12 on: June 13, 2019, 12:09:02 AM »
Sad to say but yes, I think that would be the easiest solution.
Offline TPS
  •  2,627 2,627
« Reply #13 on: June 13, 2019, 11:12:34 AM »
had a quick look to the UC100 manual Appendix A. : New functions and bug fixes:
it should Support M10/M11.
but don't know wether it is working
« Reply #14 on: June 13, 2019, 11:17:08 AM »
Yes, I saw this but I think is only compatible with UCCNC because in Mach3 doesn't works 😭
Offline TPS
  •  2,627 2,627
« Reply #15 on: June 13, 2019, 11:36:52 AM »
never used it, but M10P1 means Switch Output 1 ON, and to what (ports&pins) is your Output#1 assigned.
for the Moment you use M3/M5 to turn laser ON/OFF?
what is your output configuration Config -> Ports&Pins -> Spindle Setup -> Relay Control ?
are you using are original UC100 or a chinese clone?
« Reply #16 on: June 13, 2019, 11:48:29 AM »
I use M10 and M11 with original UC100 cable, I posted my configuration files before
Offline TPS
  •  2,627 2,627
« Reply #17 on: June 13, 2019, 11:51:35 AM »
sorry missed that you posted your Profile.
you are Controlling your laser via Spindle Motor control step Signal (chankspindle/chankspindleoutput).
output1 is assigned to pin0 (chankoutputs), so M10P1/M11P1 can not work (should be pin17)
« Reply #18 on: June 13, 2019, 11:59:08 AM »
Could you modified my profile file please and re-send me then I'll try it, Thanks for your help
« Reply #19 on: June 13, 2019, 12:21:17 PM »
I modified everything you told me and everything works same as before 😭
