Hello Guest it is October 25, 2026, 12:34:43 AM
Author Topic: Need help with tool offset  (Read 7495 times)
« on: May 27, 2019, 09:46:44 AM »
Hello, I am retrofitting an old masterwood project 309 and I am currently trying to set the tool offsets. My machine has an machine head with alot of tools on it. These tools have a fixed postion so they would need an offset in relation to the master tool. I am using mach4 and an csmio controller.
Could someone help me how to define those x and y offsets in relation to the master tool? If it is even possible.
Thanks in advance.
Re: Need help with tool offset
« Reply #1 on: May 27, 2019, 11:55:58 PM »
drill  head or multi spindle?
« Reply #2 on: May 28, 2019, 11:43:09 AM »
Drill heads,  two spindels and also horizontal drills
« Reply #3 on: May 28, 2019, 04:44:30 PM »
as i told you before  ,drill head mange not so simple ,first need create optimizer to chose the correct bit and if need activate more then 1 in one time(like drill line
also need do some more works ,like go down drilll head ,run ...
i didnt use the drill bit as new tool ,i create macro that calculate offset per bit
and its work very good
goodluck
« Reply #4 on: May 29, 2019, 04:15:47 AM »
goodluck
Thanks for the information. Is it possible for you to share these macro's with me. Maybe i could understand it better that wat and maybe try to replicate Them.
Thanks in advance
