Mach Discussion => Mach4 General Discussion => Topic started by: jelle_bos on May 27, 2019, 10:46:44 AM
Hello, I am retrofitting an old masterwood project 309 and I am currently trying to set the tool offsets. My machine has an machine head with alot of tools on it. These tools have a fixed postion so they would need an offset in relation to the master tool. I am using mach4 and an csmio controller.
Could someone help me how to define those x and y offsets in relation to the master tool? If it is even possible.
Thanks in advance.
drill head or multi spindle?
Drill heads, two spindels and also horizontal drills
as i told you before ,drill head mange not so simple ,first need create optimizer to chose the correct bit and if need activate more then 1 in one time(like drill line
also need do some more works ,like go down drilll head ,run ...
i didnt use the drill bit as new tool ,i create macro that calculate offset per bit
and its work very good
goodluck
goodluck
Thanks for the information. Is it possible for you to share these macro's with me. Maybe i could understand it better that wat and maybe try to replicate Them.
Thanks in advance
