Hello Guest it is November 13, 2026, 11:49:10 AM
Author Topic: Lines in finished Carve  (Read 11208 times)
« on: May 20, 2019, 01:48:07 PM »
I am still very new to Mach 3 and CNC router
I ran this carving today with a 1/16 tapered ball nose with a 6% step over 80 in per minute and I hope you can see the textured finish that It produced wondering if it is in the machine itself or a software issue? I will provide answers to questions about settings if needed.
TIA
Offline ZASto
  •  434 434
Re: Lines in finished Carve
« Reply #1 on: May 20, 2019, 05:53:50 PM »
Is 1/16 tip diameter?
If yes, you should take smaller step over.
My personality is who I am.
« Reply #2 on: May 20, 2019, 05:57:00 PM »
Yes  .0625 taperd ball nose.  Smaller than 6%?
That's what everyone recommended.
« Reply #3 on: May 20, 2019, 06:07:59 PM »
What kind of wood, and what software created the g-code?
What RPM were you running at.
You would typically get a much better finish than that with 6% stepover.
« Reply #4 on: May 20, 2019, 06:25:45 PM »
I use Vcarve pro. Gcode was made from an STL model.
I was cutting Hard Maple at 18k or 24k on my 3hp water cooled spindle
« Reply #5 on: May 21, 2019, 08:39:43 AM »
Somebody suggested my CV settings are off.
Do these look right?
I have an import machine with mach3 USB hook up
