Hello Guest it is November 26, 2026, 02:37:43 AM
Author Topic: Mill-Turn  (Read 12234 times)
Mill-Turn
« on: May 02, 2019, 11:19:22 PM »
I'm starting to look into turning machines and all I know at the moment is that there exist simple turning machines with a movable tool post, anything more complex than that is a bit over the top of my head at the moment. I haven't quite figured out what Mill-Turn is, but does Mach 3/Mach 4 support mill-turn?
Offline reuelt
  •  520 520
Re: Mill-Turn
« Reply #1 on: May 03, 2019, 01:03:26 AM »
Mach 3/Mach 4 support supports lathe with more than 2 axes. But must use LATHE profiles and NOT mill profiles if you want to do turning.
"the gift of God is eternal life through Jesus Christ our Lord"
Re: Mill-Turn
« Reply #2 on: May 03, 2019, 06:18:03 AM »
Thanks, found the Turn manual for Mach 3. Why didn't I think of this before!
Re: Mill-Turn
« Reply #3 on: May 04, 2019, 10:00:20 AM »
I had a read of the Mach 3 Turn manual - well, most of it and did a bit more research into lathes so a little bit more clued in now.
I don't see any mention in the manual on how to work with additional axis other than X and Z. DROs seem to only exist for these two. Where can I find some info on adding additional axis?
From my research up to this point, it seems that all I most likely will need, is a 3 axis lathe.
« Last Edit: May 04, 2019, 10:01:54 AM by Spandex »
Offline TPS
  •  2,627 2,627
Re: Mill-Turn
« Reply #4 on: May 04, 2019, 11:21:46 AM »
also lathe mode can handle more axis, only the Standard Screen set is made with X and Z.
if you Need more the X and Z a Little bit of screenset work is necessary.
Re: Mill-Turn
« Reply #5 on: May 05, 2019, 04:36:13 AM »
Thanks will look in that direction.
Re: Mill-Turn
« Reply #6 on: May 05, 2019, 05:21:17 AM »
Spandex,
The standard lathe screen set leaves a lot to be desired. An improved screen set can be found here:
http://www.machsupport.com/forum/index.php/topic,13548.msg88932.html#msg88932
If you want  an updated screen set with the Y axis ( posted lset in reply #47) can be found here:
http://www.machsupport.com/forum/index.php/topic,13548.msg234493.html#msg234493
« Last Edit: May 05, 2019, 05:23:37 AM by RICH »
Re: Mill-Turn
« Reply #7 on: May 12, 2019, 07:38:12 PM »
Well after doing more research, I realized I was getting ahead of myself. It seems there's a reason why lathes are two axis predominantly and Mills are three. For low quantity hobby production, pretty much everything can be made with just these tools, just needs multiple setups.
