Mach Discussion => General Mach Discussion => Topic started by: Spandex on May 03, 2019, 12:19:22 AM
I'm starting to look into turning machines and all I know at the moment is that there exist simple turning machines with a movable tool post, anything more complex than that is a bit over the top of my head at the moment. I haven't quite figured out what Mill-Turn is, but does Mach 3/Mach 4 support mill-turn?
Mach 3/Mach 4 support supports lathe with more than 2 axes. But must use LATHE profiles and NOT mill profiles if you want to do turning.
Thanks, found the Turn manual for Mach 3. Why didn't I think of this before!
I had a read of the Mach 3 Turn manual - well, most of it and did a bit more research into lathes so a little bit more clued in now.
I don't see any mention in the manual on how to work with additional axis other than X and Z. DROs seem to only exist for these two. Where can I find some info on adding additional axis?
From my research up to this point, it seems that all I most likely will need, is a 3 axis lathe.
also lathe mode can handle more axis, only the Standard Screen set is made with X and Z.
if you Need more the X and Z a Little bit of screenset work is necessary.
Thanks will look in that direction.
Spandex,
The standard lathe screen set leaves a lot to be desired. An improved screen set can be found here:
http://www.machsupport.com/forum/index.php/topic,13548.msg88932.html#msg88932
If you want an updated screen set with the Y axis ( posted lset in reply #47) can be found here:
http://www.machsupport.com/forum/index.php/topic,13548.msg234493.html#msg234493
Well after doing more research, I realized I was getting ahead of myself. It seems there's a reason why lathes are two axis predominantly and Mills are three. For low quantity hobby production, pretty much everything can be made with just these tools, just needs multiple setups.
