Hello
Guest
it is
October 22, 2026, 04:29:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Loop Counter
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Loop Counter (Read 7553 times)
rhtuttle
575
Loop Counter
on:
April 29, 2019, 12:43:32 PM »
When you run a subprogram (i.e. m98 p1234 L10) is there a register or other accessible variable that can be accessed to display the current loop number, the number of loops left and number of loops requested?
TIA
RT
smurph
1,575
"That there... that's an RV."
Re: Loop Counter
Reply #1 on:
April 30, 2019, 09:25:32 PM »
Not at the moment.
Steve
rhtuttle
575
Re: Loop Counter
Reply #2 on:
May 01, 2019, 10:01:16 AM »
Soooo....you're saying there may be hope?
smurph
1,575
Re: Loop Counter
Reply #3 on:
May 01, 2019, 11:17:03 AM »
Well... no. Other than the way G code already gives you. This is usually done in the G code with a #var. Set the var to zero before the M98 L10 call and in the sub increment the #var.
Steve
Print
Pages:
1
Go Up
« previous
next »
