Hello Guest it is October 22, 2026, 03:58:33 PM
Author Topic: Loop Counter  (Read 7552 times)
Loop Counter
« on: April 29, 2019, 12:43:32 PM »
When you run a subprogram (i.e. m98 p1234 L10) is there a register or other accessible variable that can be accessed to display the current loop number, the number of loops left and number of loops requested?
TIA
RT
Offline smurph
  •  1,575 1,575
Re: Loop Counter
« Reply #1 on: April 30, 2019, 09:25:32 PM »
Not at the moment.
Steve
Re: Loop Counter
« Reply #2 on: May 01, 2019, 10:01:16 AM »
 Soooo....you're saying there may be hope?   ;D
Offline smurph
  •  1,575 1,575
Re: Loop Counter
« Reply #3 on: May 01, 2019, 11:17:03 AM »
Well...  no.  Other than the way G code already gives you.  This is usually done in the G code with a #var.  Set the var to zero before the M98 L10 call and in the sub increment the #var.
Steve
