Hello
Guest
it is
November 13, 2026, 10:53:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
PWM inverter for 12 VDC motor
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PWM inverter for 12 VDC motor (Read 16519 times)
vladimir059
22
on:
August 28, 2007, 04:20:29 AM »
Hello everybody!
I have 12VDC spindle motor. Can you point me to a good PWM inverter which can be controlled by Mach3 (speed an direction)?
Thank you in advance
Vladimir
Jeff_Birt
1,107
Re: PWM inverter for 12 VDC motor
Reply #1 on:
August 29, 2007, 09:29:28 AM »
If you have a 12VDC motor you don't need an inverter (which converts DC to AC). You need to look for a speed controller that will drive a 12VDC motor.
Happy machining , Jeff Birt
Check out
www.soigeneris.com
vladimir059
22
Reply #2 on:
August 29, 2007, 12:12:31 PM »
Thank you Jeff ,
I'm sorry, this is terminology mistake. Yes I'm looking for a speed controller which drives 12VDC motor and controlled by PWM impulses generated by Mach3
I'm looking for a diagram or something from the shelf.
Best regards
Vladimir
Reply #3 on:
August 29, 2007, 01:54:46 PM »
Have a look at Peter Homann's board. could be what you are after
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=1&products_id=21
vladimir059
22
Reply #4 on:
August 29, 2007, 02:32:05 PM »
Thank you Hood! I think it is all I need
Best wishes
Vladimir
Jeff_Birt
1,107
Reply #5 on:
August 29, 2007, 03:27:57 PM »
The Homan Digi-Speed board converts the Mach PWM signal into an analog reference voltage, you still need a speed controller. A quick search turned up this:
http://www.centent.com/cn0105.htm
Never used on of them though, but it might give you an idea of what to look for.
Check out
www.soigeneris.com
vladimir059
22
Reply #6 on:
August 29, 2007, 04:49:35 PM »
Thank you Jeff.
I will check it out.
Vladimir
Print
Pages:
1
Go Up
« previous
next »
