Hello Guest it is November 13, 2026, 09:59:25 AM
Author Topic: PWM inverter for 12 VDC motor  (Read 16513 times)
« on: August 28, 2007, 04:20:29 AM »
Hello everybody!
I have 12VDC spindle motor. Can you point me to a good PWM inverter which can be controlled by Mach3 (speed an direction)?
Thank you in advance
Vladimir
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: PWM inverter for 12 VDC motor
« Reply #1 on: August 29, 2007, 09:29:28 AM »
If you have a 12VDC motor you don't need an inverter (which converts DC to AC).  You need to look for a speed controller that will drive a 12VDC motor.
Happy machining , Jeff Birt
« Reply #2 on: August 29, 2007, 12:12:31 PM »
Thank you Jeff ,
I'm sorry, this is terminology mistake. Yes I'm looking for a speed controller which drives 12VDC motor and controlled by PWM impulses generated by Mach3
I'm looking for a diagram or something from the shelf.
Best regards
Vladimir
« Reply #3 on: August 29, 2007, 01:54:46 PM »
Have a look at Peter Homann's board. could be what you are after
http://homanndesigns.com/store/index.php?main_page=product_info&cPath=1&products_id=21
« Reply #4 on: August 29, 2007, 02:32:05 PM »
Thank you Hood! I think it is all I need
Best wishes
Vladimir
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: August 29, 2007, 03:27:57 PM »
The Homan Digi-Speed board converts the Mach PWM signal into an analog reference voltage, you still need a speed controller.  A quick search turned up this: http://www.centent.com/cn0105.htm
Never used on of them though, but it might give you an idea of what to look for.
« Reply #6 on: August 29, 2007, 04:49:35 PM »
Thank you Jeff.
I will check it out.
Vladimir
