Hello Guest it is October 22, 2026, 05:55:59 PM
Author Topic: Steps per unit wizard  (Read 10644 times)
« on: April 24, 2019, 08:01:11 PM »
I try to use the steps per unit wizard
And is not working or maybe I'm doing
Something wrong...I'm using 4.2.0.4162...
Offline reuelt
  •  520 520
Re: Steps per unit wizard
« Reply #1 on: April 25, 2019, 12:11:21 AM »
I think, Mach4 doesn’t have an axis calibration wizard like Mach3 does.
There is an excel spreadsheet (somewhere in this forum) that can help you do the calculation.
What motion controller are you using with MACH4?
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: April 25, 2019, 06:16:12 AM »
I'm using MB2 Bob with ESS...
If you have mach4 look at that wizard
Button ...
Offline reuelt
  •  520 520
« Reply #3 on: April 25, 2019, 07:05:44 AM »
Sorry, I was wrong.
Is this the Wizard you are talking about as in the ebay tutorial by NFS?
https://www.youtube.com/watch?v=d-xCWDR0Uvg
« Reply #4 on: April 25, 2019, 07:59:44 AM »
Yes ..but is not working right now
« Reply #5 on: April 25, 2019, 08:50:13 AM »
Hello Greg,
Can you tell me more about what you're seeing for an issue? How is it not working?
Thank you,
Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
« Reply #6 on: April 25, 2019, 10:13:03 AM »
When I press ok I get this message
Lua:Syntax error during  pre-compilation
« Reply #7 on: April 25, 2019, 10:16:05 AM »
Hello Greg,
There is no 'OK' option in the StepsPerUnit wizard. What are you clicking before you get that error message?
If you haven't already, you should watch the YouTube video linked in a previous comment, which shows you how to use the wizard correctly.
If you see the error message again, post a screenshot if you're able to.
Thank you,
Bryanna
« Last Edit: April 25, 2019, 10:26:20 AM by bryannab »
« Reply #8 on: April 25, 2019, 12:47:20 PM »
Update: This issue was resolved by deleting the .mcs file for the StepsUnitCalculator from the Wizards subfolder in the Mach4Hobby directory. That file still held the remnants of the older version of the wizard from before Greg updated to build 4162. After that file was deleted and Mach4 restarted, all is working as it should.
-Bryanna
