Hello Guest it is October 02, 2026, 02:46:03 AM
Author Topic: Reversed Jog, on Jog TAB / Control Screen  (Read 17324 times)
« on: April 21, 2019, 02:17:29 AM »
Hi All
I am new to MACH 3, currently using NC Studio on my other CNC Router.
I have the problem of the Jog control operating ALL axis in reverse. At first, I thought it was the keyboard, so I changed the key association, which worked, but when I tried using the Jog Control in Mach 3, it was still reversed. I have tried a few things in the setup, but nothing I do is changing the directions. Please help.
Thanks Andrew
Offline TPS
  •  2,627 2,627
Re: Reversed Jog, on Jog TAB / Control Screen
« Reply #1 on: April 21, 2019, 02:37:24 AM »
Config -> Homing/Limits -> Reversed should help
Offline reuelt
  •  520 520
« Reply #2 on: April 21, 2019, 02:44:35 AM »
(deleted)
« Last Edit: April 21, 2019, 02:48:32 AM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #3 on: April 21, 2019, 03:29:46 AM »
Thank you for the reply...I have tried this and it didn't seem to work. Do I need to do a reset or something after?
Thanks Andrew
  •  9,374 9,374
« Reply #4 on: April 21, 2019, 03:59:13 AM »
Some changes to Mach3 do require a re-start this may be one of them ?
Perhaps try it and see.
Offline reuelt
  •  520 520
« Reply #5 on: April 21, 2019, 04:21:28 AM »
Please see attached to reverse direction.
(I had deleted my earlier post because I thought TPS's solution would work but it will only work for ref.all home)
« Reply #6 on: April 21, 2019, 05:16:51 AM »
Thank you. I will try this tomorrow and let you all know how I get on.
Kind Regards
Andrew
« Reply #7 on: April 22, 2019, 06:44:31 AM »
This worked..Thank you very much.
« Reply #8 on: April 22, 2019, 07:45:23 AM »
If it jigs the wrong way, then your axes are setup backwards.
« Reply #9 on: May 06, 2019, 01:43:54 AM »
Hi All
Thanks Andrew
I have exactly the same problem.  Anyone got a suggestion?
