Hello
Guest
it is
October 21, 2026, 04:38:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Homing Slave Axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Homing Slave Axis (Read 14623 times)
AlfredoG
2
Homing Slave Axis
on:
August 22, 2007, 11:53:12 AM »
Hi, I use Mach3, in X have Slave axis when homing X the slave axis have no movement, only X is moved
Greolt
956
Re: Homing Slave Axis
Reply #1 on:
August 22, 2007, 04:49:00 PM »
AlfredoG
Try checking the "Home Slave Axis with Master Axis" box on the general config page and see if the slave moves with the X axis then.
I know this may not be what you ultimately need but just see if it works.
Perhaps you could post your XML file so we can have a look. What version of Mach are you using?
Greg
AlfredoG
2
Reply #2 on:
August 22, 2007, 10:16:44 PM »
i use Mach3 version r2.00.065, both axis moves in any command, only is stopped when press reference button for homing
Greolt
956
Reply #3 on:
August 22, 2007, 10:41:33 PM »
AlfredoG
Are you using the printer port or ncPod or something else?
Do you have homing switches on both sides? Or only one on the axis?
If you have two, is one of them already active when you press home? Look on the diagnostics page.
If you only have one then the "Home Slave with Master Axis" setting should be checked.
Although the "Home Slave with Master Axis" setting is not on that version of Mach.
I would recommend updating to the current lockdown version. I think it is 2.4
Greg
Brian Barker
3,860
Reply #4 on:
August 23, 2007, 08:46:14 AM »
To home both at the same time you need to change the code of the Ref to the following
Refcombination(9)
The vlaue that you pass is done by adding the following
x=1
y=2
z=4
a=8
b=16
c=32
So as you can see in my example I am Refing the X and A at the same time
Hopet hat helps
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
