Hello
Guest
it is
October 22, 2026, 04:49:43 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
changing mach from inches to run a gcode output in mm
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: changing mach from inches to run a gcode output in mm (Read 21469 times)
airbrush
35
Re: changing mach from inches to run a gcode output in mm
Reply #10 on:
April 15, 2019, 03:23:37 PM »
or if its output from the cam as mm and in the gcode its already set to g21...then just leave that and mach (set in inches) will be fine....
joeaverage
7,663
Reply #11 on:
April 15, 2019, 03:28:52 PM »
yep.
Print
Pages:
1
2
Go Up
« previous
next »
