Hello Guest it is October 22, 2026, 04:19:09 PM
Author Topic: changing mach from inches to run a gcode output in mm  (Read 21467 times)
Re: changing mach from inches to run a gcode output in mm
« Reply #10 on: April 15, 2019, 03:23:37 PM »
or if its output from the cam as mm and in the gcode its already set to g21...then just leave that and mach (set in inches) will be fine....???
« Reply #11 on: April 15, 2019, 03:28:52 PM »
yep.  :D
