Hello Guest it is October 04, 2026, 10:24:41 PM
Author Topic: Lazy Cam Issues  (Read 36704 times)
Offline pat
  •  11 11
Lazy Cam Issues
« on: March 28, 2006, 01:43:45 PM »
Hi Brian,
I finally got Lazy Cam loaded and running. Looks like it's going to be a really nice tool when fully implemented.
But newbie that I am, I have a few questions/issues as follows:
1. I don't see the execute button that is shown on the video.
2. I can't rotate the image on the screen to see a 3d view. Rotation doesn't appear to work the same as Mach3.
3. No matter what I try I can't get it to generate more than 1 pass.
For instance if I set my final depth to .125 and depth per pass at .060. Lazy Cam seems to generate only one pass at .060
TIA,
Pat
Re: Lazy Cam Issues
« Reply #1 on: March 28, 2006, 02:47:49 PM »
OKay this is good :)
There is a bug so it can;t put out more than one pass depth :( The good side is that I have fixed it for the next release :)
There no longer is an execute button...
and to rotate the view press the middle mouse button.
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline pat
  •  11 11
Re: Lazy Cam Issues
« Reply #2 on: March 28, 2006, 04:31:36 PM »
Thanks for your rapid reply.
Wha'ts the ECD for next release.
TIA,
Pat
Re: Lazy Cam Issues
« Reply #3 on: March 28, 2006, 04:56:38 PM »
If I can get out of work it should be tonight :)
www.machsupport.com
Offline pat
  •  11 11
Re: Lazy Cam Issues
« Reply #4 on: March 28, 2006, 10:55:20 PM »
Hey Brian,
Once again thank you for your rapid response. Lazy cam now shows multiple passes graphically but the exported file is single pass, appears to be the first pass only.
Pat
Re: Lazy Cam Issues
« Reply #5 on: March 29, 2006, 05:01:10 AM »
is this in rev 1.04?
www.machsupport.com
Offline pat
  •  11 11
Re: Lazy Cam Issues
« Reply #6 on: March 29, 2006, 12:43:54 PM »
Hi Brian,
Re. Previous Posts:
My comment.
Your Response.
Yes I'm using ver. 1.04 and all I see in Mach 3 is a single first pass
Pat
Re: Lazy Cam Issues
« Reply #7 on: March 29, 2006, 01:53:29 PM »
Cool I will check it out and see if I can find a problem
www.machsupport.com
Re: Lazy Cam Issues
« Reply #8 on: March 29, 2006, 05:22:35 PM »
hi brian
lazy cam v 1.04
all get is black screen  dxf file will import i get all layers can not see chain
do not have 3 botton mouse
Offline pat
  •  11 11
Re: Lazy Cam Issues
« Reply #9 on: April 02, 2006, 05:47:45 PM »
Hi Brian,
I just downloaded the 3/30/05 version of version 1.04 and now multipass G code is generated and seems to work correctly in Mach3
Thanks.
Pat
