Hello Guest it is October 20, 2026, 04:05:14 PM
Author Topic: What is the minimum PC required.  (Read 10914 times)
Offline coogrrr
  •  13 13
  • Vrooom!!
    • la de da
« on: August 16, 2007, 11:12:56 AM »
To run a 4 axis machine what is the minimum PC requirements. I will have XP installed but is 256mb ram enough is a P3 900mhz enough? I would be only running Mach3 nothing else on this machine.
Coog
300IPM - DIY router made from David Steele's plans and serious modifications!
Re: What is the minimum PC required.
« Reply #1 on: August 16, 2007, 01:06:17 PM »
I have run Mach on a lesser computer but maybe I got lucky with my computer, I have had some that didnt work too well and were 2000MHz plusl.  Best thing to do is run the driver test and see how that performs.
Offline Whacko
  •  239 239
  • Happy Days
« Reply #2 on: August 16, 2007, 01:35:44 PM »
You would be better of by installing video card with lots of memory and more ram. Disable peripherals you don't need in the BIOS, that'l lighten the cpu load and free some IRQ shared services, and also less interupt calls.
Whacko
Nothing's impossible
Offline coogrrr
  •  13 13
  • Vrooom!!
    • la de da
« Reply #3 on: August 16, 2007, 04:25:32 PM »
Hood, Whacko.
Thx for the speedy reply guys! Ok got a good card (check) got everything else disabled or not running that is not needed (check) got a bump to 512mb looking to make it a gig soon (check). Run test!?!?!  I am at work has to wait till later  :(
Coog
