Hello Guest it is November 22, 2026, 02:27:45 PM
Author Topic: Feed Rate mm/sec to mm/min  (Read 28409 times)
« on: April 05, 2019, 05:58:21 AM »
Hello
I have a feed rate issue from running a Multicam Post Processed file on Mach3 for CNCRP.
I think I have fixed most of the other problems but cannot find a way of changing the feed rate units from mm/sec to mm/min without manually changing the g-code itself.
Is there a setting in Mach3 I can change for this?
Many thanks
Edward
Offline ZASto
  •  434 434
My personality is who I am.
Re: Feed Rate mm/sec to mm/min
« Reply #2 on: April 05, 2019, 07:21:57 AM »
What CAM software are you using?
« Reply #3 on: April 05, 2019, 09:13:23 AM »
UPDATE
I think I was not completely clear earlier. We have a large library of g-code files (around 300) and want to run these directly on our new machine Mach3 CNCRP Pro. The code seems to work fine (with a few settings changed) except for the feed rate which is at mm/sec in the file and mm/min in Mach3.
Making changes to the post processor or g-code is not really an option as it will mean having to manually alter over 300 files - it may come to this but I would like to avoid it.
So my question is can I change the feed rate units at the Mach3 end of things? - not the post processor or gcode end.
Many thanks
E
« Reply #4 on: April 05, 2019, 09:32:40 AM »
Not that I'm aware of.
« Reply #5 on: April 05, 2019, 10:25:55 AM »
How about if you could modify the FRO to go to 600%  ?
Would that not feed 10 mm/sec in the code, 10 mm/min on the machine ?
Russ
« Reply #6 on: April 05, 2019, 10:33:41 AM »
I think you'd need 6000%.
Then there's that Mach3 bug that can cause issues when running over 200%....
« Reply #7 on: April 05, 2019, 10:54:20 AM »
Hmmm ... wasn't aware of the bug.
But, wouldn't you just multiply by 60 (600%) ?  seconds to minutes ? not mm to meters ?
« Reply #8 on: April 05, 2019, 11:22:22 AM »
100% is normal speed.
100x60 = 6000
« Reply #9 on: April 05, 2019, 11:31:24 AM »
 ::) dohhhhh  ;D, Sure you're right.
