Hello Guest it is November 22, 2026, 02:28:56 PM
Author Topic: Feed Rate mm/sec to mm/min  (Read 28410 times)
Re: Feed Rate mm/sec to mm/min
« Reply #10 on: April 05, 2019, 11:39:39 AM »
Just wondering if Mach4 could effectively multiply the feedrate by 60.
If so, maybe Mach 4 would be an option to consider ?
« Reply #11 on: April 06, 2019, 09:49:18 AM »
Sounds like you need someone to write you a simple utility to scan teh Gcode and Convert all the "Fnnn" strings to ( Fnnn X 60).
Just a thought , (;-) TP
Offline reuelt
  •  520 520
« Reply #12 on: May 01, 2019, 04:54:50 PM »
Hello
I have a feed rate issue from running a Multicam Post Processed file on Mach3 for CNCRP.
I think I have fixed most of the other problems but cannot find a way of changing the feed rate units from mm/sec to mm/min without manually changing the g-code itself.
Is there a setting in Mach3 I can change for this?
Many thanks
Edward
I think it could be done using a MACH3 BRAIN.
I will try to create one BRAIN ASAP. Just trying to make certain which DRO label means what.
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
« Reply #13 on: May 03, 2019, 01:47:31 AM »
Hello
Many thanks
Edward
Sorry, i tried but it cannot be done.
