Hello Guest it is November 11, 2026, 10:28:50 PM
Author Topic: Mach4 Pokeys57E Registers  (Read 31413 times)
« on: March 24, 2019, 01:07:19 PM »
I haven’t installed the Pokeys57E plugin yet because I don’t have the device yet. Will the plugin show the Pokeys registers in the Mach4 Register Diagnostics? Like this picture below.
If so I assume I could get and set the value of the Pokeys pin with code like this:
Code: [Select]
function GetRegister(regname)
local hreg = mc.mcRegGetHandle(inst,string.format("iRegs0/%s", regname))
return mc.mcRegGetValueString(hreg)
end
--add TB 01-09-18 add Pirce Delay Register value
local val = mc.mcProfileGetString (inst, "Registers", "PierceDelay" , "nf")
local hreg = mc.mcRegGetHandle (inst, "iregs0/PierceDelay" )
mc.mcRegSetValueString(hreg, val)
--end add
Will changing the pin value change the pin state?
Offline thosj
  •  542 542
Re: Mach4 Pokeys57E Registers
« Reply #1 on: March 25, 2019, 09:37:33 AM »
Looks like there are PoKeys registers, lots of them.
Don't know about changing value changing state.
Tom
Tom
« Reply #2 on: March 25, 2019, 10:17:07 AM »
Thank you Tom,
That answers all my questions. I should be able to change the value and state of most of those "pins" with code.
« Last Edit: March 25, 2019, 10:18:40 AM by Tony Bullard »
« Reply #3 on: November 09, 2019, 04:10:29 PM »
 :( I tried to change the value of the register on the pokeys but didnt work ....please help
« Reply #4 on: May 22, 2020, 03:52:54 PM »
https://www.youtube.com/watch?v=P_vKWz55DkU here i show you how to edit registers and write into them with a servo example
