Hello Guest it is October 15, 2026, 01:15:08 PM
Author Topic: Is there a Gcode command to reference all axis home?  (Read 17542 times)
« on: March 21, 2019, 05:36:24 PM »
When I am hogging material off for a rough clean up some times I lose a couple of steps. For the roughing it doesn't really matter, but it does on the following steps.
Is there a Gcode command that will reference all axis home?
I know about the G28 command but this only returns the axis to the home position, it doesn't appear to reference it from the switch if it's off a few steps.
Re: Is there a Gcode command to reference all axis home?
« Reply #1 on: March 21, 2019, 09:29:48 PM »
no, there is no Gcode that does that.
There is however a Mach function that does it:
LUA Syntax:
rc = mc.mcAxisHomeAll(
   number mInst)
Description:
Used to start an axis homing.
Parameters: Parameter Description
mInst The controller instance.
Returns: Return Code Description
MERROR_NOERROR No Error.
MERROR_INVALID_INSTANCE The mInst parameter was out of range.
MERROR_NOT_NOW The operation could not be completed at this time.
Thus you could use the API in a macro.
Or you could call the RefAllHome() function (in the screen load script)
Code: [Select]
-- Ref All Home() function.
function RefAllHome()
    mc.mcAxisDerefAll(inst)  --Just to turn off all ref leds
    mc.mcAxisHomeAll(inst)
    coroutine.yield() --yield coroutine so we can do the following after motion stops
    ----See ref all home button and plc script for coroutine.create and coroutine.resume
    wx.wxMessageBox('Referencing is complete')
end
« Reply #2 on: March 22, 2019, 07:47:45 AM »
There is a G Command that will home an axis.
G28.1   It is on page 37 of the mill programming manual.
I just tested it here at work on a mill with the ESS and it works.
I found that it needs to be programmed like G28, with a G91
So, do the following.
G91 G28.1 Z 0.00
G91 G28.1 X 0.00 Y 0.00
G90
Be sure to set your machine back in absolute mode with the G90.
Chad Byrd
« Reply #3 on: March 22, 2019, 08:23:52 AM »
Hi Chad.
Are you referring to the doc in the M4 download ? Mine is different.
Or are you in M3 ?
Russ
Offline Bill_O
  •  615 615
« Reply #4 on: March 22, 2019, 08:33:17 AM »
I am using the
G90
in M4 and it works great.
Bill
« Reply #5 on: March 22, 2019, 08:53:26 AM »
Hi Bill.
I don't doubt that it works in M4, as it worked well in M3 but I don't see it in the M4 manual. Mine goes from 28 to 30.  Do you have it in a M4 manual ?
« Reply #6 on: March 22, 2019, 09:06:01 AM »
It's in the Mach4 manual.  Page 37.
Chad Byrd
« Reply #7 on: March 22, 2019, 09:07:12 AM »
Hello,
G28.1 is included in the Mill G Code Programming document in the Mach4 Docs folder. The one I'm looking at is version 1.1, build 3775 and is included in 4.2.3804 and onwards.
-Bryanna
Newfangled Solutions Helpdesk: http://support.machsupport.com
YouTube Support Channel: https://www.youtube.com/c/MachSupportOfficial
« Reply #8 on: March 22, 2019, 09:19:53 AM »
Thanks bryannab,
I have 1.0 .
A day late and a dollar short again.
Cheers,
Russ
Oh, I got it here
https://www.machsupport.com/help-learning/product-manuals/
You might want to update that.
« Last Edit: March 22, 2019, 09:22:19 AM by Overloaded »
« Reply #9 on: March 22, 2019, 09:27:34 AM »
Thanks Chad.
The current manual has not replaced the old one yet on the website under Mach4 Manuals.
Russ
