Hello Guest it is October 24, 2026, 05:28:10 PM
Author Topic: Pokeys57cnc homing not seting axis to zero  (Read 6845 times)
Offline gorf23
  •  190 190
« on: March 10, 2019, 05:55:26 PM »
Pokeys57cnc Homing.
When I home an axis, the home led is set to green but the axis is never set to zero, its always off sometimes only a couple thou but others times a lot..
also doesn't seem to back off.
Also has anyone used pin 17 for pwm spindle, maybe its me but seems backwards to me I connected a volt meter and I get 8.26volts at 0 rpm and  0.016 at 3600 rpm
shouldn't it go up as the rpms increase not down? and thought it was suppose to reach 10v?
Thanks gary
Re: Pokeys57cnc homing not seting axis to zero
« Reply #1 on: March 10, 2019, 06:10:54 PM »
have a look at the machine Diagnostics page. I suspect you will find that a G92 offset (or possibly a Head or Work
Shift) is in operation. Clear that and your machine cords will be reset as normal.
Offline gorf23
  •  190 190
« Reply #2 on: March 10, 2019, 07:03:34 PM »
Nope all is set to zero g92  head and work... but still doesn't zero on home...
did get the spindle working in  the correct direction now don't know what I did just started running form 0v to 8.26 as I increase spindle speed..
go figure..
gary
Offline gorf23
  •  190 190
« Reply #3 on: March 12, 2019, 11:48:13 AM »
any other suggestions?
