Hello Guest it is November 26, 2026, 04:52:54 AM
Author Topic: CNC drive AXBB-E  (Read 20273 times)
CNC drive AXBB-E
« on: March 09, 2019, 07:17:33 AM »
Hi folks.
Anyone here have any experiences with the CNC drive AXBB-E combination board ?
At first glance, it looks to be quite a nice package. An Ethernet controller priced reasonably with well documented instructions.
Thanks for any input.
Russ
Re: CNC drive AXBB-E
« Reply #1 on: March 09, 2019, 09:19:32 AM »
I just got one last week, but haven't powered it up yet.
Not sure if they'll be releasing Mach3/4 plugins for it. I just asked on their forum
« Reply #2 on: March 09, 2019, 12:33:25 PM »
to my knowledge the UC***** series don not have realtime support for backlash comp, single point lathe threading,
realtime THC, or spindle PID (index or encoder).
If there is a specific realtime function you require be sure to ask CNCDrive.
« Reply #3 on: March 09, 2019, 01:10:07 PM »
Never crossed my mind regarding the plugin. Looks like it may be an incentive to push their own product. A plugin might be pending ... dependent on package sales and demand.
Thanks Gerry.
Valid points I also overlooked as I was considering this for a lathe .... thank you Craig,
Russ
« Reply #4 on: March 09, 2019, 01:15:09 PM »
Hi Russ,
to my knowledge the Hicon (Vital Systems), PMDX-424 (PMDX), 57CNC (PoKeys) all have single point lathe threading
support. The Ethernet SmoothStepper has added single point lathe threading within the last few months and  to support
that have introduced spindle PID which can be enacted with either index or encoder signals.
« Reply #5 on: March 09, 2019, 01:17:10 PM »
I was told they are working on the Mach3/4 plugins. Keep in mind the hardware was just released last week.
I would not recommend them for lathe use, though, as even their own software does not have a lathe mode.
« Last Edit: March 09, 2019, 01:43:08 PM by ger21 »
« Reply #6 on: March 09, 2019, 01:37:40 PM »
Hi Russ,
I have a good history w/Steve at PMDx, might go that route, thanks Craig.
Coincidence, me just happening to notice their new board. (it does however say "first 250 ..." )
Could have sworn they had TURN as part of their sw earlier .... must have seen that elsewhere. ::)
Thanks Gerry
I also notice Centroid / Acorn sw and boards only work together.
« Last Edit: March 09, 2019, 01:43:26 PM by ger21 »
« Reply #7 on: March 09, 2019, 01:43:53 PM »
I edited my post and your quote, as I meant to say I would NOT recommend them for lathe use.
« Reply #8 on: March 09, 2019, 02:17:58 PM »
I did assume that  :), thanks again,
Russ
« Reply #9 on: March 09, 2019, 02:36:04 PM »
OK, that was Eding.
