Hello Guest it is November 26, 2026, 04:52:51 AM
Author Topic: sketcher  (Read 6259 times)
sketcher
« on: March 07, 2019, 11:37:24 PM »
Is it possible to enter into sketcher workbench directly?
Re: sketcher
« Reply #1 on: March 09, 2019, 12:41:05 PM »
Hi.
what do you mean?
What is 'sketcher workbench'? I assume it is some sort of drawing program. If that is the case then no, Mach4
will not run such a program.
The normal course of events is to use a drawing or drafting program to draw your part. The use a CAM program
(and post processor file) to generate GCode.
GCode is the standard code required by the vast majority of CNC machines and for which CNC software like Mach4
operates.
