Hello Guest it is November 23, 2026, 02:07:34 AM
Author Topic: mach3 problem steppers wont move  (Read 10619 times)
« on: March 07, 2019, 02:24:10 PM »
I have a problem with a machine purchased from eBay
The machine has a built-in driver such as in the picture (jp-3163).
I have a connection with the LPT port because after pressing the emergency button I see the message estop.
The problem is that immediately after turning on mach3, stepper motors stop having a holding moment.
After rebooting before turning on mach3, everything returns to normal.
Have you ever had a similar problem?
Offline reuelt
  •  520 520
Re: mach3 problem steppers wont move
« Reply #1 on: March 10, 2019, 08:35:05 PM »
Perfectly normal.
You need to click on [RESET] in Mach3 to start working.
First let us know what happens when you click on [RESET] in Mach3.
By the way do you have limit/home switches wired up (yet)?
Is jumper 3 actually in the  2-3 position and NOT in the 1-2 position as in your uploaded picture?
If jumper 3 is in 2-3 position, you will need to enable pin 1 in Mach3.
« Last Edit: March 10, 2019, 08:52:14 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
« Reply #2 on: March 10, 2019, 08:57:52 PM »
Perfectly normal.
correction
If jumper 3 is in 2-3 position, you will need to enable pin 14 in Mach3.
« Reply #3 on: March 12, 2019, 05:32:09 PM »
correct!!!
Thak You reuelt for help :)
