Hello Guest it is November 13, 2026, 08:09:21 PM
Author Topic: Spindle relay on by M3 command  (Read 10833 times)
« on: February 19, 2019, 06:15:07 AM »
Hi ,
I have a TB6560 board and I can control relay (black relay on low right in image atached) with F5 key or with Spindle CW F5 button on Mach3 interface but when I try to put M3 command in my G code nothing happends.
How can I control that relay to work with M3 M5 command?
Offline TPS
  •  2,627 2,627
Re: Spindle relay on by M3 command
« Reply #1 on: February 19, 2019, 08:08:26 AM »
any documentation about this board?
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
« Reply #3 on: February 19, 2019, 03:45:08 PM »
Here all docs I have about this TB6560
Offline ZASto
  •  434 434
« Reply #4 on: February 19, 2019, 11:53:05 PM »
The problem has nothing to do with TB6560 chip, which is, by the way, crap.
My personality is who I am.
Offline TPS
  •  2,627 2,627
« Reply #5 on: February 20, 2019, 12:31:46 AM »
ok found some additional Information, where it Looks like relay Output is port1 pin1.
so check:
->Config -> Ports & Pins -> Spindle Setup
    -disable spindle relays is not selected
    -ClockWise (M3) Output# is 2
->Config -> Ports & Pins -> Output Signals
   -Output #2 is enabled
   -Output #2 port is 1
   -Output #2 pin number is 1
