Hello Guest it is October 30, 2026, 01:30:49 PM
Author Topic: Reverse run  (Read 18822 times)
Reverse run
« on: February 07, 2019, 05:04:31 AM »
Hi all, I’m trying to do a reverse run in mach3 in order to attempt to go back and try a pierce again, but the problem is when I do a reverse run the z axis moves up and hits the limit switch and there after it takes me back to 0 ,can someone please shed some light on this and explain how the reverse run should be done correctly?
Bradley
