Mach Discussion => FAQs => Topic started by: Bradnificent on February 07, 2019, 06:04:31 AM
Hi all, I’m trying to do a reverse run in mach3 in order to attempt to go back and try a pierce again, but the problem is when I do a reverse run the z axis moves up and hits the limit switch and there after it takes me back to 0 ,can someone please shed some light on this and explain how the reverse run should be done correctly?
Bradley
