Hello Guest it is October 28, 2026, 10:14:39 AM
Author Topic: Mach 3 totaly crashed.  (Read 8713 times)
« on: February 04, 2019, 04:25:23 PM »
Hello!
I have a problem with Mach 3. When I click on the icons to start mach mill or mach lathe all i get is a white screen and the computer locks and has to be rebooted. Where do I start to figure out what's going on? I'm running windoze XP with a parallel port setup.
  •  9,375 9,375
Re: Mach 3 totaly crashed.
« Reply #1 on: February 05, 2019, 12:40:15 AM »
I would be inclined to make a secure backup of the Mach3 folder (just in case) then re-install Mach3 over the top of the existing installation (sounds like you have lost or overwritten one of the files Mach requires for it's boot operation).
« Reply #2 on: February 05, 2019, 02:15:21 PM »
OK buddy! I'm heading out to the garage with a thumb drive right now. Thanks!
« Reply #3 on: February 05, 2019, 06:09:18 PM »
Tried to re install but no luck. Then I did an uninstall and a reinstall and that did the trick. Thanks!
