Hello Guest it is October 22, 2026, 06:21:30 PM
Author Topic: Message opening by Gcedit  (Read 6436 times)
« on: February 03, 2019, 01:23:37 AM »
Hello,
It is a period when I open Gcedit this message appears to me.
I do not understand what I have to do to eliminate it.
Note:
it only makes me on that computer, I tried to uninstall and install Mach4, but to no avail.
Re: Message opening by Gcedit
« Reply #1 on: February 03, 2019, 03:33:25 AM »
There seems to be an issue when using 'Match Case' option when using Find or Replace functions in gcEdit.
Open the following file, where <account name> is your Windows user account name
C:\Users\<account name>\AppData\Roaming\gcEdit.ini
Scroll down to MatchCase=4
Set MatchCase=0
This issue will reappear if you select 'Match Case' again. The match case function still works, its just an annoying message box
« Reply #2 on: February 03, 2019, 11:50:31 AM »
Yes!!
solved as you said!
 thanks!!
