Hello
Guest
it is
October 22, 2026, 05:33:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Message opening by Gcedit
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Message opening by Gcedit (Read 6434 times)
daniba73
288
on:
February 03, 2019, 01:23:37 AM »
Hello,
It is a period when I open Gcedit this message appears to me.
I do not understand what I have to do to eliminate it.
Note:
it only makes me on that computer, I tried to uninstall and install Mach4, but to no avail.
Logged
SwiftyJ
233
Re: Message opening by Gcedit
Reply #1 on:
February 03, 2019, 03:33:25 AM »
There seems to be an issue when using 'Match Case' option when using Find or Replace functions in gcEdit.
Open the following file, where <account name> is your Windows user account name
C:\Users\<account name>\AppData\Roaming\gcEdit.ini
Scroll down to MatchCase=4
Set MatchCase=0
This issue will reappear if you select 'Match Case' again. The match case function still works, its just an annoying message box
Logged
daniba73
288
Reply #2 on:
February 03, 2019, 11:50:31 AM »
Yes!!
solved as you said!
thanks!!
Logged
Print
Pages:
1
Go Up
« previous
next »
