Hello Guest it is November 13, 2026, 03:47:14 PM
Author Topic: pendant  (Read 9795 times)
Offline josh
  •  101 101
pendant
« on: January 20, 2019, 07:18:14 PM »
don't know if mach can do this?
so I am building a lathe  and I am trying to see if a can add a pendant or a joystick
that can move the Z and X axis at the same time but it records every move than it saves it into a program
has anyone done something like this
thank you
Re: pendant
« Reply #1 on: January 20, 2019, 11:42:23 PM »
Mach3 has a Teach function.....if you start <Teach> and execute MDI code a file is generated which remembers
the sequence of instructions and can repeat it.
I don't know whether that extends to either jog or pendant commands. Simple enough to try it.
Offline josh
  •  101 101
Re: pendant
« Reply #2 on: January 21, 2019, 12:34:42 AM »
thank you for the reply
my next question would be if theres any pendant or joystick
that controls the Z and X AXIS at the same time  don't know if it makes any sense
but its basically connecting both X and Z into 1 joystick so when you move at a 45degree  angle just with the joystick it records you Z and X movement.
hope this makes some kind of sense
thank you
Re: pendant
« Reply #3 on: January 21, 2019, 12:49:25 AM »
Mach3 can jog axes similtaneosly...not easy to control with an MG or joystick but it can be done.
Offline TPS
  •  2,627 2,627
Re: pendant
« Reply #4 on: January 21, 2019, 01:28:24 AM »
mach3 can not "record" the movements, but what you can do is,
create 3 Buttons.
1.-button1 -> create teachfile
2. enter in MDI Spindlespeed , Start spindle, start coolant and what else you Need
3.-jop to a Position
4.-press button2 witch put's the actual Position with a "G1 Xactpos Zactpos" into the file
5.-repeat 3. and 4. so many times you what
6.-press button3 to end teaching
button1 and button3 allredy exist in 1024 screenset (more or less).
