Hello Guest it is November 13, 2026, 12:17:33 PM
Author Topic: Reversing DRO Direction  (Read 9908 times)
Offline engineerpower
  •  4 4
  • Learn by Doing
    • DangerCo!
« on: January 02, 2019, 09:29:17 AM »
BLUF: I am trying to figure out how to reverse the DRO direction in MACH 3 so that moving the table to the left (tool to the right) results in a positive DRO movement rather than a negative.
Sorry if this as been addressed, but the search functionality is letting me down...
I have an Enco 91002 converted to CNC, running (SolidWorks) to (CamBam) to (Ethernet Smooth Stepper) to (G540). The way it is currently set up a table move left or towards me is a negative movement on the DRO, and right or away from me is a positive movement. I would prefer this to be reversed. I have been able to do this by changing the "scale" for the X and Y to "-1.0", but I would prefer a non-temporary solution. My Z axis behaves fine, down is negative, up is positive.
My first milling experience was on manual machines, first dials then a DRO that behaves like I want. My preference would be that my CNC VMC behaves the same, and my jobs aren't cut rotated 180* on the table.
Haven't seen a setting I can change (other than scale) to do this. Do y'all have the answer, por favor???
Cameron Husk
Dir, Engineering - DangerCo, LLC
"Therefore, worry not for the morrow; the morrow shall worry for itself. Sufficient unto the day is the evil thereof." -Matthew 6:34
Offline TPS
  •  2,627 2,627
Re: Reversing DRO Direction
« Reply #1 on: January 02, 2019, 02:21:41 PM »
Config  -> Port's & Pin's -> Motor Output's -> DirLowActive
is your friend
  •  4 4
  • Learn by Doing
    • DangerCo!
« Reply #2 on: January 02, 2019, 09:50:42 PM »
Vielen dank!
That did it. Had to reverse homing direction and remap my movement hotkeys, but it's performing just the way I was trying to get it...
Mein Fallschirmjäger bruder und Ich in Afghanistan.
Cameron Husk
