Hello Guest it is October 24, 2026, 08:55:41 AM
Author Topic: Mach 4 and ATC  (Read 21371 times)
Mach 4 and ATC
« on: December 29, 2018, 02:10:48 AM »
Hello,
The Search in Forum is Broken (error message) and the google links to the forum are also all broken (maybe URL or Forum change?).
I evaluate to use Mach 4 for one of my CNC, but I can not find out weather it is possible to use the automatic tool changer with length sensor or not.
Seems there is a Script editor in "Operator" -> "Edit Scripts" -> "M6", but I am not able to find any example script for using this for a Toolchanger.
Any Tips where to start?
Has anyone got Mach 4 working with a Toolchanger?
Re: Mach 4 and ATC
« Reply #1 on: December 29, 2018, 02:36:01 AM »
Mach4Hobby/LuaExamples/ToolChanger.....you will find examples. You will almost certainly have to edit/modify the code to suit
your particular machine.
Mach4s strength is its ability to be customized, to accommodate very different toolchangers for instance, but it will require you learn to code
in Lua and using Machs modular structure.
Re: Mach 4 and ATC
« Reply #2 on: December 29, 2018, 03:18:29 AM »
Thank you, but I can not find Mach4Hobby nor I can find LuaExamples nor I can finrd ToolChanger...
Maybe thoase boards aren't visible for me?
Forum seems to be broken in many Ways.
Also the button "Spell Check" give an error message:
2: pspell_new(): PSPELL couldn't open the dictionary. reason: No word lists can be found for the language "en".
File: /var/www/vhosts/machsupport.com/forum.machsupport.com/forum/Sources/Subs-Post.php
Line: 1301
Re: Mach 4 and ATC
« Reply #3 on: December 29, 2018, 03:21:44 AM »
If you mean the folder on Harddrive which comes with Mach4Hobby - there is LuaExamples, but no scripts related to M6 or Toolchange...
Re: Mach 4 and ATC
« Reply #4 on: December 29, 2018, 11:14:08 AM »
yes there is....I have just been reading the four scripts in Mach4Hobby/LuaExamoles/Toolchanger....they are there.
Note these files are .mcs files (MachCodeSource) and you will need a text editor like word to read them.
The search function has been broken for about six-eight weeks. I don't know what NFS is trying to achieve with this, as far as I can tell its
just pissing everyone off! >:(
Re: Mach 4 and ATC
« Reply #5 on: December 29, 2018, 11:29:39 AM »
Find attached an Image of my folder.
Seems I dont have those files in the free download version - maybe you can post yours as example?
Have I done something wrong?
Re: Mach 4 and ATC
« Reply #6 on: December 29, 2018, 12:48:04 PM »
don't know why your installation does not have the files, mine does.
Re: Mach 4 and ATC
« Reply #7 on: December 30, 2018, 01:57:18 AM »
Is there any way to contact the "professional" support?
Maybe they forgot to package it in the newest version.
At least they could fix the forum to find stuff which maybe is already solved.
But there is no answer on my mail until now...
Re: Mach 4 and ATC
« Reply #8 on: December 30, 2018, 04:55:28 PM »
You can use email support from the website.  They usually get back within a day.
Chad Byrd
Re: Mach 4 and ATC
« Reply #9 on: December 31, 2018, 02:03:56 AM »
Maybe they are off over the holidays. Now answer since 4 days, but lets wait. Tnx you all.
