Hello Guest it is November 13, 2026, 12:58:02 AM
Author Topic: maximum work area  (Read 21973 times)
maximum work area
« on: December 28, 2018, 11:21:53 AM »
I have scoured the manual and cannot find what the max work area for mach 3 is. If my part is less than 12" x 16" all data imports into mach 3, if larger only part of it imports. Any thoughts?
Offline Stuart
  •  311 311
Re: maximum work area
« Reply #1 on: December 28, 2018, 11:36:39 AM »
Do you have a valid license for your mach3
« Reply #2 on: December 28, 2018, 11:39:46 AM »
Yes
« Reply #3 on: December 28, 2018, 11:48:50 AM »
you can cause the machine boundaries to be displayed on the toolpath screen if the setting is made in Config/Toolpath per the attached.
The boundaries are the soft limits in Config/Homing-Limits page.
If a Gcode file is loaded which is larger than the boundaries it should still be displayed but the job could not run without going out-of-bounds.
Unless mach3 is licenced (check Help/About to confirm licence status) it will load only 500 lines.
« Reply #4 on: December 28, 2018, 01:44:21 PM »
Thanks, I seem to be well within the machine boundaries. I know mach 3 is supposed to accept 100,000 line of gcode but this seems to be stopping at 2500.
« Reply #5 on: December 28, 2018, 05:42:39 PM »
I have regularly loaded PCB etch files over 100,000 lines in both Mach3 and Mach4.
Regrettably I managed to lose my Mach3 licence file a few months back and as I use Mach4 now I haven't
been bothered to replace it....ergo I can't load a big file in Mach3 to demonstrate....but certainly when I was still using
Mach3 two years ago I was running files of 100,000 lines.
  •  9,377 9,377
« Reply #6 on: December 29, 2018, 01:19:01 AM »
Hi Rockyrude,
Try turning off the Toolpath Display (Diagnostics screen). If your Gcode now runs without issue then it indicates that you need to fit a higher spec (more memory) Graphics card or possibly just update the drivers for your existing card.
« Reply #7 on: December 29, 2018, 08:22:56 AM »
The are no physical size limits, and Mach3 can run up to 10,000,000 lines of code. Typically, the lack of a license file, or an error in the g-code would be the only thing keeping the toolpath from being displayed.
« Reply #8 on: December 29, 2018, 08:27:51 AM »
As noted I have a legal license file. I probably need to get better at gcode. Using notepad to look at the gcode file, I am not seeing anything wrong at the line mach 3 stops. Also I am running a 2mb graphics card, seems like should be good enough.
« Last Edit: December 29, 2018, 08:29:56 AM by rockyrude »
« Reply #9 on: December 29, 2018, 08:45:09 AM »
Is Mach3 giving you a message?
