Hello Guest it is October 21, 2026, 02:55:35 AM
Poll
Of all the people out there that have a system with two parallel ports, how many have the second port wired with pins 2-9 as inputs vs. having them wired as outputs?
On my second port, pins 2-9 are used for inputs.
13 (68.4%)
On my second port, pins 2-9 are used for outputs.
6 (31.6%)
Total Members Voted: 19
Author Topic: More inputs or more outputs, you decide.  (Read 24056 times)
« on: August 07, 2007, 03:14:46 PM »
OK guys, This is a question for all. This is going to help guide the development of a new product, so please vote. If you don't use a second port, still vote as to what you would like to see, more inputs, or more outputs. I know, more of both. But, if you had to choose, which would it be?
Re: More inputs or more outputs, you decide.
« Reply #1 on: August 07, 2007, 05:20:48 PM »
"if you had to choose one" it would be a UBS port capable of handling both. I know that not on your poll. But you asked
« Last Edit: August 07, 2007, 05:22:45 PM by Lakeside design »
« Reply #2 on: August 07, 2007, 05:32:06 PM »
Right you are LSD, Hmmmmmmmm, that didn't come out right.
All jokes aside, you are exactly right. That is the plan actually, more of each but it will most likely be heavier on one than the other so keep this in mind while casting your vote.
« Reply #3 on: August 07, 2007, 05:39:41 PM »
You are the first one to pick up on  that. It is my little joke
« Reply #4 on: August 08, 2007, 07:02:56 AM »
Bump   ;D
Offline moxy
  •  34 34
« Reply #5 on: August 08, 2007, 08:36:01 AM »
Hi Brett, I reckon I could use a few more inputs......then I could fit a whole lot more switches on my mill!!!! When will it ever end?
 Regards
Les
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #6 on: August 08, 2007, 10:33:16 AM »
I take it you are designing a USB to parrallel port type of output - or a card to fit in the computer to give x and y numbers or inputs and outputs.
If Mach3 is designed for 6 axis we need two outputs for each (12) then outputs for spindles (2 or 3) spindle speed ???? (?) and then coolant (2) - we are on about 17 there - so might as well make it 24 ( 3 x 8) or 32 ( 2 x 16)
Inputs - 3 per axis (18) and I would think another 14 on top of that to bring us up to 32 would suffice.
If the finished card - had 32 inputs and 32 outputs I would have thought you could cater for all of Mach3 requirements.
« Reply #7 on: August 12, 2007, 10:21:57 AM »
HI, I feel that there should be about twice as many inputs as outputs, I would like to add a auto tool changer and a probe. in the future.
What would be needed so Mach could regulate the voltage across a plunge type EDM machine, using a stepper to move the electorde?
« Reply #8 on: August 12, 2007, 06:12:14 PM »
What I would like is an in/out card that catered for 2 parallel ports with a choice on the second for pins 2-9  ins or outs and a serial port connection for extra outputs...
Oh and perhaps a small programmable controller so we could configure a tool-changer without Mach doing all the work in a VB script.
and.. and.. and..   ;D
Or could the USB could manage all this?
« Reply #9 on: August 12, 2007, 06:25:36 PM »
Thanks for the replies guys, and the votes. I can't talk about what it will be or how many of what, or all you'll be getting, but it is certain to please the masses.  ;D
