Hello Guest it is November 15, 2026, 06:33:34 PM
Author Topic: Setting up spindle control does M3 and M4 change dir pin  (Read 7684 times)
« on: December 19, 2018, 04:58:08 PM »
Ok new with MACH 3 and trying to connect a cnc4pc C11G Bob to my X2 mill. So I am going to setup pin 14 as the step pin per G11G manual. So I would like use the dir pin to control a relay to change direction of the motor .
My question is if I issue M3 or M4 command will one command make for pin high and one low?
Offline TPS
  •  2,627 2,627
Re: Setting up spindle control does M3 and M4 change dir pin
« Reply #1 on: December 20, 2018, 01:20:43 AM »
declare your out here, and do the Setup (port/pin) for the Output.
