Hello
Guest
it is
November 23, 2026, 10:13:48 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
4° axis help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 4° axis help (Read 27229 times)
francopuk
42
4° axis help
on:
November 15, 2005, 02:45:15 AM »
Hi, i search any example of g-code for working 4° axis (for example write on the pipeline or tube)
thank in advance
Franco
Logged
Brian Barker
3,860
Re: 4° axis help
Reply #1 on:
November 15, 2005, 12:43:44 PM »
Franco,
You are going to have to have Y axis sub... This is done in the low cost cam systems and you are going to have to use a cam system to make the code.
Hope that helps
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
