Hello Guest it is October 24, 2026, 08:41:11 PM
Author Topic: Problem with an MPG  (Read 5280 times)
Offline MN300
  •  306 306
Problem with an MPG
« on: December 17, 2018, 01:24:54 PM »
The manual pulse generator mentioned in this website was installed according to the instructions provided.
https://shane.engineer/blog/making-a-generic-pendant-work-with-mach-4
When an axis was selected the carriage immediately moved at whatever jog speed was set. Turning the MPG encoder would add to the speed. The solution was to filter the A and B encoder inputs with a filter value of 1.
The system has an ESS board with a MX4660 on ports 1 and 2, and a C10R10 BOB on port 3 for the MPG
It’s a mystery why those two functions interact. I am adding this post to help anyone who has the same problem and in hopes someone from Artsoft will address it.
