Hello Guest it is October 30, 2026, 06:05:11 PM
Author Topic: Motors turn with G code but not with keyboard...Help!  (Read 31713 times)
« on: December 09, 2018, 04:17:25 PM »
Mach 3 running G code fine but can not jog with the keyboard.
Ports-Pins settings must be right cause the G code will turn the motors.
Keyboard edits code so it must be working right.
The keyboard just aint talking to the motors.
Any ideas??
Re: Motors turn with G code but not with keyboard...Help!
« Reply #1 on: December 09, 2018, 04:18:24 PM »
You can only jog on screens where there is a jog On/Off button. That might be the issue?
« Reply #2 on: December 09, 2018, 04:22:10 PM »
That was a fast response. THANKS!!
UPDATE....  The DRO's will not move using the keyboard either. (using the arrows and page up and page down)
« Reply #3 on: December 09, 2018, 04:39:20 PM »
It certainly sounds like jogging is turned off, or maybe you are in MPG mode?
« Reply #4 on: December 09, 2018, 07:27:46 PM »
UPDATE:    Looks like the MPG flyout is not working right (Press tab key it shows on the screen)
I get a Yellow LED when I press Shuttle Mode
No LED shows at Jog mode.
Where do I turn on Jog Mode?
« Reply #5 on: December 10, 2018, 11:56:53 PM »
To answer my own question after doing a bit of research....  Ctrl-Alt-J turns On/OFF Jog Mode.... Heck it is right on the dang Button under tool information duh!
Odd place for it but it is there.
