Hello Guest it is October 05, 2026, 06:20:34 AM
Author Topic: Mach3 Digitizer  (Read 12882 times)
Mach3 Digitizer
« on: December 09, 2018, 01:30:35 PM »
Hi Everyone
I have a mold i would like to make a digital file of to reproduce the mold.
I would like to make a pointcloud like i understand the digitizing wizard should. ( I cant get it to work)
I would really like to set a vector boundry for the probing, is there a plugin/addon That can do That?
I have search on Google all day and every link goes to the built in digitizing wizard or external software for probing 2d/edgefinding etc.
Every solution is very welcome!!!!
My machine is a homebuilt CNC router with Mach3 and ESS + working probe for automatic tool measuring.
First time since building my router that i cant google my way to the answer.
Really Hope someone out there can help me.
Thanks for your time :)
Offline TPS
  •  2,627 2,627
Re: Mach3 Digitizer
« Reply #1 on: December 09, 2018, 11:13:24 PM »
there are digitice wizards avaliable, have a look to the installed wizards.
Re: Mach3 Digitizer
« Reply #2 on: December 10, 2018, 01:57:25 AM »
Hi i cant the built in wizard to work i cant change the x,y probing area its always zero. When i change it it will return with zero. I have tried returning to standart mach3 screen and still the same.
All the other settings i can change
Offline TPS
  •  2,627 2,627
Re: Mach3 Digitizer
« Reply #3 on: December 10, 2018, 10:43:58 AM »
i have tryed the "Standard" witch came with Mach3 Digit wizard
you have to type in a value and press enter, that's it
Re: Mach3 Digitizer
« Reply #4 on: December 10, 2018, 11:44:02 AM »
When i type a number and hit enter the number returns to zero the very moment i hit enter... really frustrating.
But i would also like to contain the probing to a vector or shape that i can draw.
If its not possible i am sure i can work around the square probing area.
Is there a newer/different digitizer?
Offline TPS
  •  2,627 2,627
Re: Mach3 Digitizer
« Reply #5 on: December 11, 2018, 07:45:14 AM »
attached a Version where all Parameters are shifted to an other aeria, may it helps.
just unzip it into addon Folder.
Re: Mach3 Digitizer
« Reply #6 on: December 11, 2018, 04:06:38 PM »
Thanks a lot i will try it this weekend (crazy life kids/work etc.)
All be back with the results
Re: Mach3 Digitizer
« Reply #7 on: December 21, 2018, 02:19:11 AM »
Thank you it worked perfect!!
