Hello Guest it is November 23, 2026, 10:13:47 AM
Author Topic: 4th Axis when Slave in Use  (Read 9111 times)
« on: December 09, 2018, 01:08:38 PM »
Hopefully this is in the right section. I have a Gecko540 controller running two steppers on the Y-Axis with one being slaved to A. X is X and Z is Z.
I've just made a rotary axis which is currently being run as the X-Axis. Is there a way to make this axis angular and retain the two steppers on the Y? Is it possible to slave the X axis to Y and then use A on the rotary? Or is there another way? Currently I have it as a linear setup and I don't know if I have it setup correctly in terms of steps etc...
Re: 4th Axis when Slave in Use
« Reply #1 on: December 09, 2018, 01:26:25 PM »
Are you trying to run 5 motors from your G540?
« Reply #2 on: December 09, 2018, 01:29:51 PM »
No four.
I have Y and A Slaved to run the Y axis, as I have two steppers on the Y.
Z runs Z
and X runs rotary at present.
I'd like to display the rotary as an angle if possible.
« Reply #3 on: December 09, 2018, 03:33:52 PM »
Assign the A motor pins to the B axis, and slave B to Y.
Assign the X motor pins to the A axis.
« Reply #4 on: December 10, 2018, 04:22:46 AM »
That's worked perfectly! Thanks, it's been doing my head in all weekend!
