Hello Guest it is November 22, 2026, 06:52:55 PM
Author Topic: I'm having trouble using the forum's search engine  (Read 12001 times)
« on: December 09, 2018, 10:56:35 AM »
When using the search engine I'm receiving this error message and can't figure out what I'm doing wrong.
:2: pspell_new(): PSPELL couldn't open the dictionary. reason: No word lists can be found for the language "en".
File: /var/www/vhosts/machsupport.com/forum.machsupport.com/forum/Sources/Search.php
Line: 700"
Any help would be appreciated.
Thanks, Tom
Re: I'm having trouble using the forum's search engine
« Reply #1 on: December 09, 2018, 12:25:01 PM »
I am having the same problem with no mater what I put in the search field.
Offline Stuart
  •  311 311
« Reply #2 on: December 09, 2018, 12:32:54 PM »
Don’t worry guys it’s the same for us all , it ‘K’ for not working
You would think the prop,e at ArtSoft would have put up a sticky to inform the great unwashed and to prevent people getting the knickers in a twist
Although there have been lots of posts about this you could have just scrolled down a few pages and seen a result
« Reply #3 on: December 09, 2018, 12:41:13 PM »
Thanks Stuart I just scrolled down to the first one I found.
Tony
  •  9,378 9,378
« Reply #4 on: December 10, 2018, 12:55:22 AM »
Good point Stuart, consider it done.  ;)   http://www.machsupport.com/forum/index.php/topic,38933.msg262556.html#msg262556
« Last Edit: January 09, 2019, 01:58:43 AM by Tweakie.CNC »
« Reply #5 on: December 10, 2018, 08:15:10 AM »
Tweakie.CNC,  ...........thanks.
Offline jinumm
  •  1 1
  • web design company new york
    • web development company
« Reply #6 on: December 12, 2018, 11:03:36 AM »
thanks
Offline TPS
  •  2,627 2,627
« Reply #7 on: December 12, 2018, 12:59:47 PM »
how was the one called, can't remeber, ah Don Quichotte.  ;) ;)
